Faja »
https://forums.nicoclub.com/faja-u129014.html
Thu Dec 06, 2012 5:14 pm
Taken from the 2009 FSM:
The control of the parking, license plate and tail lamp operation is dependent upon the position of lighting switch. When the lighting switch is placed in the 1ST position, the BCM (body control module) receives input signal requesting the parking, license plate and tail lamps to illuminate. This input signal is communicated to the IPDM E/R (intelligent power distribution module engine room) via the CAN communication lines. The CPU (central processing unit) located in the IPDM E/R controls the tail lamp relay coil. This relay, when energized, directs power to parking, license plate and tail lamps, which then illuminate.
If your tail and parking lights are working, then I would suspect the wiring of the license plate lights is at fault somewhere along the line. If all the lights are out, then look at the IPDM and inside fusebox for a possible broken fuse or it could be the light switch not making a proper contact in the 1st position.
