2009 Rougue Oil drain plug
Rockhoundrob
Car: 2009 Nissan Rogue SL
I have changed my daughter's 2009 Rogue 3-4 times now.
I noticed when I remove the oil drainplug, there is a washer.
Does this washer need to be replaced everytime I change the oil?
Hondas and Subaru's do need new washers...
but the Chilton manual does not say anything about this.
itsa300zx
Car: 1990 300zx NA W/TT swap
2011 Nissan Rogue S
2008 Highlander SR5
Yes Nissan recommends replacing the copper crush washer, but I have reused in the past without issues. I guess if you do not over crush them they should still work again. Fine if it doesn't leak, but pain in the a** if you realize the used washer starts to leaks.
I just buy a bunch of these for pennies each.
https://www.rockauto.com/en/moreinfo.ph ... 28&jsn=435
casperfun
Car: 2009 Nissan Rogue SL AWD - Indigo Blue
I’ve never used washers and never had a leak. I eventually joined the boat for the heck of it.
itsa300zx
2011 Nissan Rogue S
2008 Highlander SR5
Never used or never changed the crush washer? Hard to believe the threads of the oil drain plug will seal as they are just straight cut threads m12x1.25, and not meant for sealing(without a crush washer).
casperfun
Well my 1990 Maxima, I never changed the washer if it even had one for a decade. Unless there was the original and I guess it was stuck there and I thought it’s that way.
I did replace my oem on the rogue with a magnetic plug and never used a washer like back with my maxima. I was never a car person so didn’t think about washers until I gain more knowledge through the internet and YouTube.
I mean, no harm, no foul back then since I never had problems.
So I now recently use washers since it’s the thing. :wavey:
Lone Wolff
Car: 2015 Nissan Rogue SL AWD
2025 Toyota Corolla Hybrid
2010 Ford F150 Lariat 4x4 5.4L
2010 Ford Fusion SEL
1968 Firebird 400
FWIW, I have never replaced the washer on my 2015. Had it since new and I change oil about every 6 months/5000 miles. Never leaked a single drop.
macgiver
Yeah you gotta just look and see if that washer crushes pretty evenly all the way round . That's when you find it being able to re-use over & over red rover. It's gonna leak , if at all is when you've first re-used the crush and didn't carefully look at it , that's when an under car check for leakage is needed for a few days after - better to check . But they're goofy alright , and usually work out ok without ALWAYS swapping in a new one :crazy:
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
Copper crushes are just about infinitely reusable if you never over-torque them. The one on our '13 Altie came with the car and still doesn't leak a drop. Keep in mind that the differential metals aren't much different from using a lockwasher. Two days after you snug it up, Mr Galvanic has already assured that the plug isn't coming out again without effort. So after the initial crush (which should be torqued to spec), if you want to keep using the same washer, the operative word is "snug" and not "re-crushed".
Jimmy9190
Car: 2018 Nissan Rogue S
I buy these off of Amazon, bag of 10 OEM crush washers for $6.00. Cheap insurance and one less thing to worry about whether I did it right.
https://www.amazon.com/gp/product/B071F ... UTF8&psc=1
itsa300zx
2011 Nissan Rogue S
2008 Highlander SR5
Agreed, it’s cheap insurance. FYI, These are also used for the cvt drain plugs.
Rockhoundrob
Oh neat!
I was thinking about changing the Diff fluid, Trans Fluid, and also the Transfer case fluid.
Each of them have the washer?
itsa300zx
2011 Nissan Rogue S
2008 Highlander SR5
Transfer case and diff use larger aluminum washer, sorry I don't know the sizes off hand. I reused mine as they look good still.
As all have said here, you can reuse them as long as they have not been over crushed/torqued.
Return to “Rogue Forum”
