casperfun wrote:Mine is bare too. I thought of using heat resistant black spray paint on it because I really don't prefer the stainless steel look at the bottom. Would it affect the integrity of the muffler no matter how miniscule it is? Just want to paint the part that shows at the bottom. Thanks ahead for any input out there .
Nope... it won't hurt a thing. Just make sure you use one of the Hi-Temp paints sold in Automotive stores designed for painting engine manifolds. There is also a hi-temp paint designed for painting barbecue grills sold at home improvement and hardware stores. Either one will work.
Also if your car has 1000 miles or more miles on it the muffler has been exposed to various forms of road oils so make sure you clean it thoroughly with good solvent like lacquer thinner or acetone prior to painting or the paint won't stick. The only thing that might look worse than an exposed shiny muffler... is a flaking black one with shiny spots peeking through. You can also use a degreaser, such as denatured alcohol. Acid etching is another possibility for preparing stainless steel to take paint. Acid etch primers use high concentrations of acids to remove an glaze and provide a bonding surface thus allowing the paint to adhere better.
That said... whatever you do.. DO NOT sand or use a wire brush to rough up the surface. What makes stainless steel "stainless" is a chromium oxide passive layer. If this layer is damaged, be it a result of the manufacturing process or by some other means, the exposed metal is able to be attacked and your stainless steel will show signs of rust. Roughing the surface with sandpaper etc., may be tempting but damaging the anticorrosive properties of the steel is too big of a risk for me.
In reality stainless steel is really only more rust resistant than standard iron based materials. Even some of the best stainless steel will show signs of rust if it was ever in contact with mild steel before it was installed. Hammer or iron tool marks on the skin can leave iron deposits. Rust can even come from when the item was slid across a mild steel work bench or from being wire brushed with a normal steel wire brush. When this occurs it's actually the iron deposits on the surface that are rusting rather than the stainless. But... stainless can rust under the right conditions, albeit slowly, so anything you add in the way of protection (i.e. paint) will help slow the process.
