Yev wrote:Hi, EricBss7. Have you checked your battery terminals for corrosion? Also, try running your wife's Rogue solely on the alternator. If the alternator is good, your car will run without a problem. If it's seen better days, your car won't be able to power all the accessories and your engine will shut off. Also, check your intelligent key fuse. Although highly unlikely, the fuse may somehow be causing electric shortages. I should add that it would be helpful if you disclosed information regarding the weather and altitude in your area. If it's really cold or the air is thin due to high altitude, I wouldn't be completely surprised. However, if the weather and altitude are average, that's something else. Last, but not least, have a mechanic check your starter. If all fails, consult a Nissan mechanic for further assistance...
Checked the battery terminals, no corrosion and they are on tight. Have not tried running it on the alternator yet, but with only 30k miles on the car, I find it hard to believe thats the problem. Also, I don't have an Intellikey, just a normal one with the alarm buttons on the key. I live in Connecticut, weather's been 50-70 lately. Here's a video of me trying to start the car (you probably need to turn up the volume), you can see at first I get nothing but lights. Then I get the car cranking to a low RPM (400-500). Finally for some reason I decided to open the door, and tried again and the car started up. I don't think it's related but still weird.
http://www.youtube.com/watch?v=rWRe57TS ... e=youtu.be
