I still have my original 2009 alternator, water pump, tensioner pulley, tie rods, wheel bearings, brake pedal sensor, and fuel pump because it’s still rock solid after all these years, so I’m still stuck with these parts because they won’t die presently.
I did change my starter with a new non-refurbished version a few years back since mine failed. That project was definitely not as easy as it looks online because I had to contort my small frame trying to successfully install that darn starter, but I was extremely satisfied with myself after getting that done!
Here’s a few more projects I personally consider:
1) new or clean wipers w/silicone spray.
2) change pcv valve for oil efficiency
3) change spark plugs
4) and ignition coils
5) original radiator should be on it’s last leg because
one day you will notice steam and you could dangerously overheat and damage your engine in the middle of driving. My heart sunk when I saw my radiator empty. If it wasn’t for my Garmin Gps that allowed me to read my coolant temperature, I wouldn’t have been able to drive and stop to keep my temp below 250-260 degrees and drive a mile or 2 when it was in a lower range. That saved me.
6) clean the throttle body
7) clean mass air flow sensor
8) bleed brake with newer Dot 4 brake fluid which is better for anti-lock brakes.
9) add fuel system cleaner of your choice because ethanol gas is crappy.
10) change cabin/engine air filters
11) rust converter liquid or spray as needed on underbody and I don’t live in the rust belt.
12) change serpentine belt if cracked.
13) add transmission cooler if you’re ocd preventive.
14) dash cams if you have crazy drivers in your city.
15) if legal, l.e.d. backup bulbs for better visibility for your daughter and others.
16) grease the battery post.
17) tire changing kit on point and inflated spare.
18) if you have an unlucky phase with nails, get tire certificates when you get new tires.
19) steering wheel cover, I like it because better control and less slippery to me.
20) zipper booklet like purse to keep insurance and registration.
21) drain/fill transmission every 20-30k miles.
