Sorry, been dormant for a few days haha. Finally got to take a long trip for work and figured it was a good time to check some of the sensors. Also found out i can stack 2 graphs on top of one another with my scanner. So below are my findings, all were cruising at 60mph with very slight hills:
Picture 1- MAF/O2 Sensor comparison
The humps are from me making sure the MAF is working properly
Picture 2- O2 Sensor(downstream)/AFR Sensor(upstream) comparison
Picture 3- (same as 2, different time)
So it looks like everything is working together the way it should, but for some reason the O2 sensor drops in voltage. Does this tell you anything?
