2009 Rogue - Is DOT 4 fluid ok?
darylzero
Just like the title says. Doing some googling it seems ok to use DOT4 instead of DOT3. Dot4 also seems to be better for anti-lock braking system. Don't know if that's true or not.
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
DOT3~4 are completely cross-compatible, they have the same basic composition (glycol) but DOT4 boils higher. DOT5 is the one you can't use, it's silicone based.
darylzero
Cool thanks Vstar650CL.
I did find this, https://www.autozone.com/diy/brakes/dot ... rake-fluid
Seems DOT4 needs to be changed more often.
VStar650CL
Technical Expert
Yep, the tradeoff for the higher boiling point is that the esters in DOT4 are even more hygrophilic (moisture-loving) than glycol. The difference isn't great, the 20% cited by AutoZone sounds about right. Keep in mind that with brake fluid, time means much more than miles, more like anti-freeze than motor oil. Climate also has a huge effect, a Florida car will need much more frequent changes than one in Arizona.
Return to “Rogue Forum”
