kerrton »
https://forums.nicoclub.com/kerrton-u88348.html
Wed Sep 03, 2014 2:04 pm
All of those parts are referring to the same CVT part which is compatible with 2008 to 2013 Rogues. I encountered the same confusion when I had my 2008 CVT replaced late in 2009. The reason for the different part numbers appears to be a scramble by Nissan to address design flaws in early models, so they made some minor design changes and referened new part numbers, but the overall CVT transmissions were still designed to work with all Rogue's.
This information was compiled over many months of research and discussion with Nissan dealership staff who helped me through my failed CVT, which was delayed repeatedly due to Nissan continually trying to fine-tune the design to address weaknesses. For many weeks I was continually told that "Nissan is working on a fix, just wait until the next version is ready". The 2009 version that I received was even referred to as a "countermeasure CVT" by one Nissan rep, who was referring to the slack belt rattling that plagued early 2008 models, and which prompted Nissan to scramble and make many minor changes to this part.
If you use online parts search web sites, they should all tell you that these parts are interchangable (because they are in fact the same part, just with some minor "tweaks"). The later the version you can get your hands on, the better. Stay away from anything 2008 or early even early 2009 if you can, in my opinion.
