sub0carfanatic »
https://forums.nicoclub.com/sub0carfanatic-u299837.html
Mon Apr 15, 2024 7:29 pm
I am getting ready for a long trip and have been wanting to change my headlamps, the Lo beams and Hi beams are two totally different shades of light. I know the low beams are HID I believe, I would like to know if the factory HID D2R type are 4300K or if they are 6000K, I wanted to get a set of high beams that are in the same light spectrum, I am just not sure if that is 4300K or what was used from the factory, I want them to all be the same color though. I want the bright white, probably around 4300k - 5000k. I am looking for a set of high beams to match the color of the low beam factory HID basically. I think the low beam HID lamps are D2R and the high beams are 9005 HB3, if I am incorrect can someone please let me know. Also I am not sure what the factory wattage is for the OEM high beams or the OEM HID lamps, I would be most appreciative
