2009 Pathfinder AC Compressor Question
meldenjr
Car: 09 Pathfinder
Hello, my name is Mark E. and i am new to the forum.
I haven troubleshooting my AC compressor in recent months and it appears to be a bad clutch.
However, many reports i have read show that the compressor will not be able to be manually turned if the clutch is bad.
With the engine off, the compressor (inside pulley) on my 2009 pathfinder can be rotated with some resistance but not much.
There is also voltage going to the compressor when the AC is activated at the console.
I also thought that there may be a bad ground from the ECM, however, i attempted to wire the compressor directly to the battery, (connected the terminal at the compressor to positive of battery, and negative terminal to the chassis) and no clutch engagement.
I also disconnected the triple pressure switch and the voltage to the compressor went to zero, reconnected the pressure switch and voltage came back. So unless there is a grounding issue at the ECM or somewhere, the pressure switch is attempting to do it's job.
I just wanted to get anyone's thoughts if i missed anything or my attempts at forcing the clutch to engage were incorrect?
i just want to exhaust my options before i break down, discharge the system, replace the compressor, and recharge.
thanks,
Mark E.
Slumpert
Car: 1997.4 Pathfinder
Your bouncing around in your post.
If your getting voltage to the compressor (actually that’s for the clutch) when you should, why are you messing with other switches and trying to confuse the problem.
Your getting power to the clutch when you should which means everything else is working.
So when your AC system is turned on, does the center engage and start turning or does it stay still?
Compressors as they wear out will become easier to turn and produce less cooling, if there is a breakage in the compressor it will become impossible to turn.
meldenjr
Car: 09 Pathfinder
No. The clutch does not engage and does not spin when AC power is applied and engine is running.
Slumpert
Perfect, now you need to decide if you want to spend $40 for a generic, @ $120 for a OEM or just go ahead and replace the compressor at this time.
meldenjr
Car: 09 Pathfinder
Any idea where I can get the generic clutch? Only place that seems to have a replacement is the dealer. Auto zone or Oriele does not stock it, only the full up compressor.
