4xq »
https://forums.nicoclub.com/4xq-u207684.html
Sun May 03, 2015 10:36 pm
Generally, a sign of low freon is your a/c works, but it just doesn't get very cold. In your case the a/c doesn't seem to be turning on properly.
Since you added a can of freon, and that did not help, I would have someone look at it. You can add too much freon, which causes pressure in the system to get too high, and it will shut the compressor off to keep it from blowing seals, etc. So I would not add more until you have it looked at.
