Hello everybody!
My Bluebird Sylphy shifter gets stuck at the P position with the knob that releases the stick refusing to be pushed fully "noting the break is fully depressed". BUT, with multiple trials of moving the stick in its place i hear the "tick" sound and the button releases allowing the stick to move normally smoothly and everything else goes normal.
So if the sensor for the solenoid valve is related to the break, why does it open when slightly moving the stick keeping the same break press?!!!
Also, sometimes right after ignition and depressing the break, i hear the tick sound and the lock opens immediately normally without trying to move the stick!!
may the stick be slightly dislocated, or needing lubrication?!! need to know the mechanism to be able to understand...
would be very grateful for any help!! Thanks!
