2009 Murano S Fog Light Wiring Harness?
Forum for the unique Murano, and official home of Nissan Murano Club!
frogger
Does anyone know if the 2009 Murano S has a wiring harness for the fog lights already installed?
tjinth11
Car: 2009 Murano S AWD
i just purchase a 2009 Murano S AWD, dealer doesn't sell fog lights, any know where i can get them and what wiring harness do i need, do i need an optical sensor too.
sir
Yes it does have it.
tjinth11
i see the wires on the driver side, i do not see the wires on the passenger side. where about is the wire.
sir
tjinth11 wrote:i see the wires on the driver side, i do not see the wires on the passenger side. where about is the wire.
That's exactly what I've seen too. I just assumed the other side is in place but I couldn't find it.
Anyone?
Thx.
smilygo
Car: 2009 Murano, 2004 Scion xA and 2004 BMW R1100S
I am having the same issue. I have already ordered the OEM Fog Light kit but cannot find the connector on the passenger side.
sir
smilygo wrote:I am having the same issue. I have already ordered the OEM Fog Light kit but cannot find the connector on the passenger side.
Did you check to see if there is power on the driver connector?I think we have to route a wire from the driver side to the passanger side.
smilygo
Sir, thank you for your input. I just ordered anOEM fog light kit from Nissan. The kit contains a cable for the passenger side per the part guy. It is possible that this cable could provide power to the passenger side. I won't recieve the kit for 10 or so more days, but I will post pictures once I get it installed. $350 investment.
frogger
Did Nissan recently release a fog light kit for the 2009 Murano? I talked to several dealers a couple of months ago and they said that they didn't have a fog light kit.
smilygo
Ok, I just installed fog lights and it took me little over 30 minutes I purchased the following items:
1 X Harness Assembly p/n 24070-1AA0A2 X Fog Lamp p/n 26150-8990B1 X Switch Assembly p/n 25560-JV12A2 X Screws pn 01115-00271
On the passenger side, you will find the connector on top of the washer tank. You need to use the Harness Assembly on the Passenger side. Installing the holding screw is a bit tricky as the washer tank interfers with your job, but you can still do it with little patience.
On the driver's side, it is If you remove the fender inner cover, you will see the connector taped to the frame.
Itook some pictures but cannot insert them here. I am going to install the switch assembly tomorrow. If anyone wants to get pictures, just send me a private mail.
sir
smilygo wrote:Ok, I just installed fog lights and it took me little over 30 minutes I purchased the following items:
I sent you a private email.Thanks.
smilygo
Sir,
I haven't recieved any e-mails.... I am trying to upload images here. Anywa, it is very easy to install fog lights.
sir
You can send the pics here: [email protected]
How difficult was the installation of the combo switch?Thanks
mprado2
Car: 2010 Murano
Smilygo:
Please send pics to [email protected]
Just bought fog light kit for 10' Murano.
Thank you.
Return to “Murano Forum”
