DotsB »
https://forums.nicoclub.com/dotsb-u135135.html
Mon Jun 01, 2009 11:44 am
Actually, a bad starter can cause the problem Phxsuns described, I just went through this myself on a different vehicle that intermittently had starting problems that went on for about 3 months. It would start fine, i'd be driving to where-evers, then once I got back into the car to start it again I got nothing... no click, no sound, zippo. Had to get a jump every time. So I got the battery and alt tested, both were ok and should have started the car fine. I ended up isolated the problem to the bad starter...so I changed it out and haven't had a problem since....that's been months ago. Battery, starter, alt...all interconnected.
HOWEVER, there's so many electronics and computers in the Murano that it could be almost anything putting a drain on the battery, or a combination of things. Yes, the dealer will have to continue troubleshooting until they isolate the problem.
