mactaite »
https://forums.nicoclub.com/mactaite-u225316.html
Thu Jul 26, 2018 5:54 pm
Hey guys,
I have an overheating problem. Drove the car yesterday and noticed it started to overheat when in idle (at a light or stuck in traffic). I turned the heater on blast which dropped the needle and was able to get home. I added coolant when the car cooled, filled the reservoir to max line, and burped the system with a funnel from the radiator cap and car inclined. Took it for a drive and thought it was fine. Today I drove it again, and about 45 minutes into the drive it started to over heat again in idle. So I let it cool and replaced the thermostat (OE specs NAPA 180 degrees). The car still is overheating after driving it for a while.
I checked the fans, they do come on with and without the AC. I did notice the reservoir is between max and min now so maybe I am losing coolant somewhere but not on the ground. It is 108 degrees in North Texas but I don't think that would cause coolant to evaporate from the reservoir.
Plan on doing a pressure test in the morning. Also, may go to the stealership and by an OEM thermostat. Any tips or suggestions to try next?
