Flynz »
https://forums.nicoclub.com/flynz-u222331.html
Fri Jul 26, 2013 6:24 pm
Greetings from CT,
I'm a new Infiniti owner having bought my first, a 2009 G37X with 26,000 miles. I love the car, just need lots of spare time to get through the manuals and figure it all out.
I do have a couple questions though. Is it normal for the auto trans. when coasting to a stop at a light or stop sign to downshift noticeably in the 10-15 mph range or so in the lower gears? If you time it wrong, you have to give it some gas to get up to the light, it really slows down any momentum.
Next, if you travel over a rough, bumpy road and keep your hand on the shift lever, you can feel it bounce in your hand, almost as if the drive train is on rubber mounts, is that a normal experience?
Lastly, both the driver side door and front passenger door lock/unlock rocker switch on the arm rests are not back lit under the unlock portion of the switch. I assume both sides are burnt out or not functional as they are both out. Is there an easy fix to get them back working and if so, how?
I look forward to my driving experience with the car and interaction on the forum.
Thanks.
Dave
