From what I understand there is a 10 inch subwoofer/amplifier assembly. I cannot verify anything because there just isn't enough information out there. There is a single woofer under the center of the rear deck. Here is an image of the label:
So, it is a Bose shallow mount Nd woofer with a model number of 28138 JK11A, unfortunately there is no success searching for that model number. So I cannot easily identify its specifications.
From what I have read here and other places it is a 2 ohm woofer, and it measures about 6 inches of mounting depth total.
My first option is to add an Infinity Basslink, and from what I understand it should be easy enough to create RCA type links out of the current woofer amp.
Second I could replace the woofer with something like a Rockford Fosgate Punch P3SD210 and replace the current amp with a Rockford Fosgate Punch P300-1. It's a two ohm setup that gets rave reviews.
Any opinions out there as to which method is preferable? Any tips or comments on the feasability of this project? Thanks for the help.
