2009 CVT Problem
Forum for the unique Murano, and official home of Nissan Murano Club!
gsxr
Car: 2009 Murano
Have a 09 Murano AWD SL whenever you change from park to drive or reverse to drive or any other combination from gear to gear it takes about Three seconds to engage from any change up or down hot or cold dealer says this is normal ???????.My 09 Altima and my 05 Murano DON'T have this issue.ANY HELP WOULD BE NICE.Thanks in advance.Happy HoHo's.
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
How is the fluid on your vehicle? Burnt, brown/ really dark red. If any of the above then flush it and see if the problem subsides. Do you have check engine light on at all?
viperdoc
Car: 2009 Murano SL, Merlot, with Nav, Premium, Tech, Leather and Dual Moonroof
I have noticed the same thing. I really does take a little extra time to go into reverse or forward gears. It has been that way from the beginning, and i just figured it was normal. All in all, a pretty minor gripe for me, as the rest of the car is amazing (other than some of the options on the Nav/Phone/CD/MP3 player gray out when you start moving- what a pain!)
2tigers
Car: 09 Murano
09 with 22K. immediate and smooth response on my CVT.
govols0511
Car: 2009 Murano LE AWD
Mine does the same thing...has since I purchased in May 09. I was told it's normal from the dealer...it bugs the crap out of me to be honest.
Doug09 LE AWD Bronze
Muranofolks
Car: 2009 Murano SL AWD
I have a 09 SL AWD that I purchased in October of 09. I don't notice this in my Murano.
woodydog
Car: 2009 Nissan Murano SL
My 09 with 16k does that as well, it seems like it takes too much time to 'engage' when going from R to D. What's worse is that heavy thud when you get impatient and hit the gas before it's engaged, then it bangs in and goes...can't be good. I asked the dealer about it and he says it's designed that way so you can't go into D while still rolling backward. I called BS, explained how I always come to a full stop before changing from R to D and vice-versa. He changed the subject. Interesting that some have this hesitation and some don't.
2young2retire
'04 with 81k miles and does not do that. Smooth transaction from reverse to drive or drive to reverse. Lags are not normal.
Czarny_Orzel
Car: 2006 Lexus GS 300 AWD & 2009 Murano LE
09 LE, with about 5k. We experience a bit of a lag only on very cold mornings, otherwise shifts seem pretty normal. One thing that I do is usually on startup I sit for 15 to 20 seconds and let the oil circulate - maybe why I'm not experienceing the long lag.
kerrton
Car: 2008 Nissan Rogue SL FWD Gotham Gray
The general rule of thumb is that the CVT should perform and feel like a conventional auto trans, in this situation it the shifts should be immediate and crisp. The first thing to check is the CVT fluid level, however on a new vehicle like this it should not be down.
Either way you've got a problem with the CVT, and you need to be persistent with the dealer and insist they correct the problem. Come armed with information, let them know that you know that this lag is not normal. This should all be diagnosed and fixed under warranty, no questions asked. You do not have to live with a new vehicle that is defective. Good luck.
Return to “Murano Forum”
