2009 Cube Charcoal Canister Location?
Home of the Nissan Cube forum and CubeDriver.com
smokeydogvol
Car: 2009 Nissan Cube
Good evening;
I have a P0455 code, so likely need to change my EVAP valve on the canister but can NOT find it to save my life. Also, can not find a single video or website explaining its location. Can anyone help me with this?
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
It's at the very back of the car, behind the gas tank on the lefthand side. You probably can't see it without lifting the vehicle.
smokeydogvol
Thank you. I'll look again, but I swear I jacked it up and did not see anything. left hand side as in driver's side? I really hope I can find it and replace this valve myself instead of taking it in. It really isn't that hard if I can just find the thing. I really appreciate it!
VStar650CL wrote:
Wed Sep 06, 2023 8:46 pm
VStar650CL
Technical Expert
IIRC it's left of center and directly behind the tank (and yes, left is driver's side), but take a look at this parts diagram, it should help you identify what you're looking for. The piece marked "Sec 223" is the canister and the rest is the plumbing:
https://www.nissanpartsdeal.com/parts-l ... m=173_A001
VStar650CL
Technical Expert
PS - Here's Sec 223 for reference, but don't ask me why they lump the canister in with the intake plenum. :crazy:
https://www.nissanpartsdeal.com/parts-l ... ?pnc=14950
smokeydogvol
Thank you so much for your patience and help! I'll check it out tonight!
I'll have to take a closer look on that side because I took it for granted it wasn't over on that side because the muffler was there. Only video I saw even close was a Versa, which is somewhat similar to the Cube and it was on the right side right next to the rear tire.
Thanks again.
VStar650CL
Technical Expert
Yah, I know for sure the Versas (and Sentras) both have it all the way on the right. It's been awhile since I worked underneath a Cube so forgive me any memory failures, but I seem to recall it being left of center beside and above the muffler.
smokeydogvol
Indeed it is! I haven't messed with it yet, but even without jacking it up I stuck my head up under the drivers side rear and could put eyes on it. I totally missed it looking from the passenger side even with it jacked up. Was just looking in the wrong place from the wrong perspective. Thank you so much.
VStar650CL wrote:
Thu Sep 07, 2023 9:57 am
VStar650CL
Technical Expert
:dblthumb:
Return to “Cube Forum”
