2009 AWD 155,000 miles - tire light flashing
Rockhoundrob
Car: 2009 Nissan Rogue SL
I looked on the internet and nothing looked helpful.
I did a seal and CV axle change on the driver side. No problem.
However, the tire pressure light flashed 60 times, then stays on when I start the car.
I am waiting for a reply from my daughter ( her car) and ask if this has been happening before.
She is the one that parked the car in the garage last night, so I don't know if this happened before I worked on the car or afterwards..
But in any case, anyone know what it means when the tire pressure light flashes 60 times, then stays on?
I checked the pressure and 3 tires was 34 and 1 was 37. I release pressure from the one that was 37 until it was 34.
C-ya
Car: 2011 Nissan Rogue SV AWD
Could it be one of the sensors is bad? Do you know if they are original?
casperfun
Car: 2009 Nissan Rogue SL AWD - Indigo Blue
Definitely change the sensors, I did mine a few years ago. :woot:
Rockhoundrob
Ok, talked to my daughter...
She said it started last month, so I guess I'll try the TPS in the tires first.
Is there way to test them?
I did get a new Autotel scanner. I hardly started using it. Maybe it can do some tests?
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
If it can read the BCM then it can read the TPMS, the BCM is in charge of that. Otherwise, a lot of free parts store scanners can read TPMS codes (but not clear them), or just about any tire store will have a full-capability TPMS scanner-programmer.
Rockhoundrob
OK, I guess it's time to get out the manual!
Return to “Rogue Forum”
