I bought this Altima in June the A/C would freeze you out of the car. a month later it would work but the recycle would keep kicking off after 40-60 min of driving. Eventually it got to a point where it would blow cool air (with recycle off) but the clutch would cycle on and off so violently it would nearly stall the engine. A mechanic checked it out added some freon and sent me on my way. it worked great for the ride home, the next day leaving work it lasted 8 min. Since then I started playing around with it. I set the low side to 30 PSI when I drove it the AC would quit and start blowing warm air. I stopped the check the low side and it was over 40 at idle let out some freon and it started working agian. For about a week it would last for about an hour then it dropped down to 15-30 min. I went back to diagnose it but now the compressor will not engage. the clutch is not frozen. I want to try jumping the pressure switch but appears you have to pull the grille/bumper cover to access it.
Is ther an easier way to access the switch?
Any thoughts on what else may be wrong with it?
I want to gather as much info as possible before dumpng money on parts I do no need.
