2009 Altima 2.5 SL not starting
General discussion area for the L32-chassis Altima
Krashk2
Car: 2009 Nissan Altima 2.5SL
I was wondering if anyone else has had the problem where the 2009 Nissan Altima 2.5 SL will not start intermittently. The car is new with only 2400 km on it. We have had to boost the car a number of times.
saywat
even tho its new maybe u got a bad battery
malnevets
Car: 07 Altima Majestic Blue
saywat wrote:even tho its new maybe u got a bad battery
I'd have to agree, if you already had to boost it many times, sounds like the battery is bad.
try complaining to the dealer for a free replacement?
Lyon
Car: 2007 Nissan Altima 2.5
Krashk2 wrote:I was wondering if anyone else has had the problem where the 2009 Nissan Altima 2.5 SL will not start intermittently. The car is new with only 2400 km on it. We have had to boost the car a number of times.
I agree with the above posts. I used to work for a dealership and cars that were not test driven were not started and the battery was dead many times. Have the dealership replace it. If it's a new car then it should be under warranty if it's less than 12 months old. If older then they prorate it. Good luck.
BJBALO
Car: 2009 ALTIMA SDN I4 CVT 2
Look for Nissan Tech Bulletin NTB10-139 dealer wants $380.00 to fix and this will be the second time in 12 months.
What's up Nissan?
Return to “4th Generation Altima Sedan (2007-2012)”
