lashus wrote:I wana buy mostly all spl parts like...
word, we will probably have similar build threads here shortly. :PI plan on tossing my **** on after february or so though.
My Mods for 09 include this though...
I have $2200 saved up right now, as soon as I hit 3gs or get close I am doing this:
Stance GR + Pro coilovers mated with...
SPL:Tension RodsInner (Tien)/Outer (SPL) Tie Rod EndsRear Traction Rods,Rear Toe Rods,Rear Upper Control Arms
Brakes:300zx 30mm front calipers (already have)300zx 30mm new front rotorsPowdercoat/clean rear calipersNew rear s13 break padsNew rear s13 rotors.
I'll probably throw new front and rear swaybars on as well. Unfortunately I don't have enough $$$ to throw down on some new front and rear lower control arms or I'd have all new suspension all around.
I haven't decided if I really want to change out the subframe bushings yet. Mine should be okay, and people have recommended against solid/aluminum subframe bushings if I DD my car, which I will. Would it at least be worth it to put new rubber / polyurethane bushings on the subframe? Could anyone recommend a good brand for them?
I also plan on maybe buying R33 GTR wheels and then my suspension/stance build should be done with the exception of lower control arms (and maybe subframe bushings?) If I can find them, I also plan on getting OEM coupe rear valences and some 180sx side skirts. I am tired of people asking me why my '300zx' looks weird...
For 08...my list got done for the most part. I wanted to swap on my silvia front end as well as put an Rb25 in my S13. Both of which were done. Hopefully 09 will go smoothly.
