2009-2014 Murano cabin air filter
Forum for the unique Murano, and official home of Nissan Murano Club!
BeBeep
Could someone please post the part number of the cabin air filter element?
Thank You
Reason: Revised title
Timmbo
Car: 2013 Infiniti JX35 AWD
2013 Nissan Maxima Sport Pkg
It is #B7277-Z51001 and is available at:
http://www.courtesyparts.com/2..._9271&
CPS
I don't know where they came up with that crazy part number, but that is not correct for the Murano, at least not the factory original Nissan part. I can't remember the exact part number off the top of my head, but it's only 10 digits, and I believe it actually starts with a B (maybe a B7277-JN20A). Maybe they have a different way of listing parts online or something.
CPS
BTW, I was right even though I pulled that part number out of thin air. B7277-JN20A is the correct Nissan number for it.
Timmbo
I just edited the post to #B7277-Z51001
BeBeep
Thank you for the help.
brainguyus
Car: '12 Nissan Murano SL
'08 Nissan Versa SL
'67 Lincoln Continental
If I ever meet the engineer who designed the placement of the cabin filter in the '09 Murano he's getting one of these.....
After removing the glove box and playing "where's Waldo" for 10 minutes I finally found the cabin filter cover. Ok good enough, I know where it is from now on. However they don't give you enough room to slide the filter in and out without deforming the filter. It takes a little patience and jiggling to make sure the filter is expanded properly in the slot. All in all about a 20 minute job once you know where everything is, but really poor design for something you need to get to every 15,000 miles.
By the way, I have 13,500 miles on my Murano now and I was surprised at how filthy the cabin filter was. It really traps alot of crud.
coachro
Do any of you know a good source for the cabin air filter (2009)? Dealer wants $48+tax.
marlin29311
Car: 2008 Infiniti G35x
Try looking at the NICO sponsors at the right of the page....the dealer wants that much because they'll install it too...which you can easily do yourself...
My dealer charges $89 to do it - I bought my filters onlike for $10 and did it myself in 15 min...
nafddur
Car: ???? Nissan Maxima
???? Nissan Murano
The last one I bought at Autozone this past spring (I forget which brand - either STP or Fram) was just under $20. Takes about 5 minutes to change, after you've done it the first time. 10-15 minutes tops the first time you do it. Should be several threads here detailing the procedure to change the in-cabin filter.
coachro
Is that for an '09 or earlier model? I specifically asked about '09 because several websites (including Autozone) don't show one for '09 models. If I'm missing it, please send the web link. Does anyone know for sure if the filter is the same for '07 and '09 or if it changed?
nafddur
???? Nissan Murano
coachro wrote:Is that for an '09 or earlier model?
Oh, sorry. Didn't notice you were asking about an 09 filter. Mine is an 04, so I've already replaced the in-cabin filter 4 times. And, if I remember correctly, I had to get the first couple filters from the dealer. If the 09 filter is different from the earlier gen Mo's (as it apparently is), you also might have to buy them from the dealer for a while.
Johns09Murano
Car: 09 Murano SL FWD Sandstone
OK - I've searched and found much info. BUT - it looks like the info is for pre-'09 cabin filter replacement. Anyone have an idea how to replace it in an '09? Dropping the glovebox by pulling pins out - doesn't seem to be an option in an '09 (pins - what pins??).
Inside the glovebox - all I see are some torx screws. Should I take them out?
Sorry if this has been asked before - any help would be much appreciated.
TIA - John
martinrrrr
Car: 2009 Nissan Murano SL w/ everything
Here is a link for the 2009+ Murano air filters. It's a little frustrating the first time but it's still fairly simple. The 2nd time around wont take very long.
[youtube]http://www.youtube.com/watch?v=z6Ta7UVl1_s[/youtube]
Reason: Fix video link
Czarny_Orzel
Car: 2006 Lexus GS 300 AWD & 2009 Murano LE
The information available from the brain trust on this forum is simply outstanding!
martinrrrr
To expand a little on the "frustrating" part. I had to use pliers to grab the filter and more less pull and tear out the filter. It didn't really tear but it deformed it pretty bad. Putting the new one in meant that I had to compress it and shove it into the slot. The slot isn't as long as the filter but I was able to compress it enough and squeeze it in and let it expand once in the slot and that was all there was to it.
Johns09Murano
martinrrrr wrote:Here is a link for the 2009+ Murano air filters. It's a little frustrating the first time but it's still fairly simple. The 2nd time around wont take very long.
http://www.nissanmurano.org/ph...ort=1
Thanks - will definitely give it a try this weekend. Bought the filter from O'Reilley's, so now....will do the install on Sat or Sun. Again - thanks for the info.
- John
brainguyus
'08 Nissan Versa SL
That's what I hate about the Murano cabin filter. You have to deform it so much to get it in that you can't be sure it's expanded correctly.
My wife's Versa is completely different. The cabin filter slides in easily and there is no doubt about correct installation. Also, the plastic cover for the Versa filter is actually part of the filter as opposed to the Murano in which it's a seperate piece.
BillArf
Car: 2011 Murano LE AWD
In regard to changing the Cabin Air Filter on a 2009, 2010, 2011 Murano:
You do not need to remove the carpet panel as instructed in the TYC instructions. If you look closely at your Murano you will see the opening where the cabin air filter cradle is located is not covered by carpet. You will see the black release tab which you push upward and "gently" that releases the cabin air filter cradle access door. The TYC instructions are correct otherwise.
Edited TYC Instructions:
bfigueroa
Car: 2010 Murano, 2007 Infiniti
Can anyone assist re: changing this filter as I do not have the TYC instructions and would really like a picture of its location or a web site video. Thanks Bob
leggguy
Car: 2014 Murano SL AWD
Can anyone help with instructions for replacing the cabin air filter on a 2014 Murano? :confused: Thanks
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
leggguy wrote:Can anyone help with instructions for replacing the cabin air filter on a 2014 Murano? :confused: Thanks
Welcome to NICO! You have a second gen Murano (2009-2014). I've merged your thread with an existing one. You'll find the answer in the previous posts above.
debloooz
Car: 2014 Murano SL
I've owned a 2009 and 2010 Murano - just got a 2014 SL. Went to change the cabin air filter as I have on my previous Muranos. . . nope! No cabin air filter behind the center console. So I looked online and saw some posts that it was behind the glove box with instructions to remove the phillips head screws, blah, blah, blah - nope! Torx screws and no label indicating a filter behind the box per the You Tube video.
Anyone know the location and/or have instructions to replace the cabin air filter on a 2014 SL? I'm assuming that it has one?
Reason: Merged with existing thread
Rogue One
2022 Honda Pilot SE
Welcome to NICO!
The 2014 is the last model year for the 2nd gen Murano, so the cabin filter will be in the same place as the '09~'13 models. It's entirely possible the filter simply wasn't in the holder.
Nissan Murano Cabin Air Filter Replacement Guide
Return to “Murano Forum”
