I searched for DDM in titles and this came up, im gonna post some info I found on a local forum I watch about DDM's quality...
Other Forum wrote:After 24 days, i finally received the HID kits i ordered. I had ordered 3 kits but only one is going in my car. I figured that for the same price as bulbs i would try it out in a non-critical area in the car (fogs)
About the order - I have seen a few others complain about the shipping time, on the site it says 1-2 weeks. They billed my card right away. After a week or so not hearing from them i had noticed that the item was now listed as temporarily backordered on the site. I wait another week and finally call them after no tracking number had appeared in my inbox. So anyway, they shipped monday, but still took a while because UPS f***ed up this time.
One intersting thing to note here-My credit card was billed directly from Apexcone, and when i called the call was answered from Apexcone. For those of you who don't know, Apexcone are one of the more common brands that make 50 watt kits. They typically sell for 100 dollars or so for 35w and 120ish for 50 watt kits on other sites.I later learned that DDM is in fact owned by apexcone so you are basically buying factory direct.
Installation went relatively smooth, with the exception of me scratching up my salt and sand covered car cause i was too lazy to wash it, and with both of the back covers on the headlight housings cracking slightly when i was drilling for the grommet and me needing to apply silicone to seal them off. Cold weather and plastic FTL.
Got everything in place without bolting up, fired them up and they worked. Being skeptical of cheap s***, i decided to try them again a couple times. Sure enough on the second try one of the ballasts failed. I immediately broke out the multimeter, which of course had low batteries and i had to replace, and checked first the input voltage at the stock leads which was fine, then from the second connector into the ballast, also fine, and then as i was trying to get the leads to stay in the output from the ballast to test it i realized i was a retard, went inside, and grabbed one of the ballasts from the other kits and swapped it in
It worked.
So i have one failed ballast. We will see how the warranty is. If you aren't used to pulling your bumper and lights you might want to save yourself the trouble of having to do all the work for nothing, and get a set of test leads with alligator clips for like 3 bucks and test everything on the battery a couple times before installing them in the housings
Anyway i will update this after i see how they hold up after a few days of cold starts and turning on and off w/ the high beams which can be rough on HID's, and when i see how the warranty is. I just wanted to post something up because people have been asking about this place
_______________________________________________________________________UPDATE #1 -
1st off, one of the ignitors is intermittently not firing, so sometimes when i shut them off and turn them back on, i have to turn the fogs on and off a couple times to get it to work. Fortunately the only time i turn them off is to flash everyone that thinks i have my high beams on because HOLY F%*K are these BRIGHT! 3000k fogs FTMFW.
It looks like a wall of light coming down the road. These overpower my headlights by so much you can only see the 6000k off to the side a little and directly in front of the car where the fogs don't cover. They are actually a bit brighter than my high beams now. I didn't even bother using the high beams unless i was flashing someone, and when i was at an intersection where cars would drive by their faces were illuminated.
When a car in front of me was going around a bend before i would just see the tails and outline of the back, along with the light from their headlamps in front of them. I now cast a shadow over everything in front of me.
I am not joking either when i say that looking at them from any distance as far as i was willing to walk from the car this cold a** night, they were BLINDING and i had to squint the whole time i walked back to the car, followed by a couple minutes of not being able to drive because i was still seeing spots
Anyway, possible this weekend i will be beefing up the headlight and foglight grounds and installing relays with 10 gauge to the fogs to try and solve the intermittent no start____________________________________________________________________This post was from STOOF, the guy with the red g37 with a black hood and cf roof
OK HERES MY REVIEW.
THESE KITS ARE GARBAGE!
I ordered:55w 8000k D2S for the low beams55w 8000k H1 for the fogs
The 55w kits are supposed to be ALOT brighter than the 35w kits. So i had to pay an extra $15 for that, and an extra $15 for the D2S bulb connectors.
I just "tried" to install the two 55w kits in my lows and fogs. And this is what i encountered.
1. They didnt give me the wire to connect the ballast to the stock harness for the D2S kit. (no biggie as i have a bunch of others which i used)2. The H1 bulb for the fog, DIDNT f***IN FIT. The bulb fit in fine, but the base of the bulb was so big, i couldnt get the clip down onto it.3. After i hooked up at least the low beam i tested it against my stock 35w 8k. They arent brighter at all.4. I ordered 8k, should be blueish, NOPE, theyre white as hell, they look like stock 4300k color. WTF.
I took them out and im going to get a refund, this is bulls***.
I also ordered a reg 35w kit 6000k for the camaro, im debating if i should even put it in or just return it._____________________________________________________________________Ok so i called yesterday with some questions about their kits, also because my best friend ordered a 35w 8000k H3 kit for his fogs, and got just bulbs, no ballast.
First of all, their customer service is absolutely HORENDOUS. TERRIBLE to say the least. They ALWAYS put you on hold, literally play the same song over and over (some terrible remake of "my humps") while having you on hold for about 10 mins to 30 mins at a time, they have maybe like 3 guys working out of a basement or something.
Second of all, They notified me that they will no longer be selling Apexcone HID kits anymore because theyre "hard to get", so theyll start selling DDM kits. They say the Ballast will be smaller than the Apexcone, no word on the difference in output.
Now im not discrediting their business with the above stated problems, but for anyone whose had problems with them like myself and a few friends, this is most likely why.
Just an FYI
