srellim234 wrote:Do you have your air select lever on bringing outside air in or is it recirculating the inside air?
Bingo. Most people think the term "Air Conditioning" means "Cold," but it isn't true. It's conditioned air, which means that both the temperature and humidity are controlled.
So when most folks see the lever position marked "MAX AIR," they think it just means maximum cold. Not true. The "Max Air" position cools down the car faster by recirculating the cooler cabin air rather than bringing in warm outside air to cool.
Unfortunately, folks forget that "Air Conditioning" removes moisture from the air, too. The amount of moisture air can hold depends on its temperature; warm air can hold a lot, cold air holds less. That's why the measure of moisture in the air is relative humidity; it's relative to the maximum amount of moisture the air can hold at its current temperature rather than a absolute measure of content. Once air reaches a 100% Relative Humidity, any attempt to add more moisture just causes the moisture to condense. That's why you can see your breath outside on a cold day.
On a cold day, the major source of moisture in the air inside the Versa is the people breathing. So, if you've got your Air Control level set to "Max Air," the moisture from everyone's breath gets recirculated, too. The air conditioner is taking some of the moisture out of the air, but when the windows are cold, it doesn't take much for the air near the windows to reach 100% relative humidity; hence the moisture condenses on the cold glass and your windows fog up.
Like srellim234 and Andrew say, don't have the Air Control level in the "Max Air" position...have it bringing in that dry outside air, instead. This diagram shows the proper position:
The only time you should run with the lever in the "Max Air" position is on hot days.
Mind you, EV provides advice completely opposite to mine...he feels the "Max Air" position is better for eliminating fogging. It's weird, because we live in the same area....
Ron
