2008 Versa SL Factory Sub woofer
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
chaneylk
Car: 2008 Nissan Versa SL
Hello, I just purchased a 2008 Nissan Versa SL. I'm getting no sound through the factory sub woofer. Is there a fuse that powers the Sub? I'm not expecting the sub to knock my socks off, I just want it to work to get the best out of the factory sound equipment.
Thank you in advance.
jordo1125
Car: 2012 Nissan Versa Hatchback Special Edition
Do you have an amp connected to it? and is your stereo aftermarket?
chaneylk
Everything is factory installed.
Athikerguy4life
Turn the radio on and stick your head next to the sub. If you hear/feel it then it working. Next, check the bass/mid/treb settings. Bass could be on 0, causing very little sound to come out. I don't have an SL sound system so thats about all the info I have for you.
Return to “Versa Technical Discussions”
