Ginsu »
https://forums.nicoclub.com/ginsu-u91170.html
Tue Mar 24, 2009 6:29 am
Never been shocked from my Versa, but in the past five minutes that I've spent strenuously researching this phenomenon online, I've discovered that you can ground yourself before stepping out of the car by touching anything metal that is connected to the frame. I can't test this for you to see if it actually works, but if it does, it sounds like an easy fix. Open the door, reach up to the roof, then step out.
Of course if you just weld your door closed and get out Dukes of Hazard style then you'll never forget.
