Base 2.0 don't have disc brakes rear. Does the hub swap require that to be swapped out as well? Just wondering.nametakennow wrote:240 owners do it all the time. You need 5lug hubs to pull this off. However, those wheels will probably be a tight fit at best... not sure of the offset or width, but I suspect it's liable to rub.
