Both of the above. You have to keep the pressure to at least 80% of what the doorjamb says otherwise the light will go on.nametakennow wrote:Welcome to NICO!
Get that tire pressure warning taken care of, it sounds annoying.
Wait awhile and see about the mileage, it will probably creep up with time.
yeah bring it back to the dealer, a bunch of guys on another forum were having that same issue. they should be able to fix it pretty easily.dedlock wrote:Lucky to have a Nissan tech as a regular contributor here.I check tire pressure regularly and it's right where its supposed to be. I did some more searching and it sounds like a bad batch of sensors may have made it through. There was mention of a service bulletin for the problem but not sure if the Sentra is specifically mentioned. Looks like a stop at the dealer.While I'm thinking of it..........do you know any detail on adding XM to the '08 Sentra? I've received different answers on compatibility. Have a 2.0S CVT w/convenience pkg and base stereo. This option level was pre-wired for XM in '07. Was the pre-wiring deleted for '08?
Sometimes, if the code is a hard code, it will take erasing to make the light go off. Meaning, if you drive TOO LONG with the light on, it sets as a hard code and can't be cleared by driving.Dominator wrote:Re: TPMS indicator light on '07 2.0S model. Similar problem, but slightly different circumstances. Recently experienced an unrepairable front passenger side flat tire, and with new tire (same type as others) mounted and balanced and properly inflated, TPMS sensor light remains on. At least I know the source of the indicator, but more than 500 miles now and still waiting for it to reset. Yes, kind of frustrating.
Did you ever find out the cause of this? Just started with mine yesterday with 699 miles on the car. It was cold outside but 50 degrees in my garage when I started it. Light came on and stayed on. Checked pressure and all OK. I hate the time and inconvenience of taking it to the dealer if it is just a malfunction that can wait until the next service required. Thanks.dedlock wrote:Hello Folks, Just registered on NICO since we now own a new Sentra 2.0S.We compared it to the usual suspects but the interior room/comfort won us over.Enjoying the car, but the mileage is less than expected. Mid 20s on highway (calculated at fill-ups not w/trip computer. This seems to be mentioned by a few of you here.On the first 10 degree morning I noticed the tire preasure warning light come on and its been on ever since. Obviously a malfunction since pressure is correct. Anyone else experiencing this?
Look forward to following the posts and adding some of my own experiences.
yea thats pretty much what i did. i got mine last winter and it hit 20F outside and the thing went off i thought i broke something.but yea in cold weather you're gonna be playing with Tire Pressure alot....i like how it says Icy when its cold alsoSTRA08 wrote:I'm new to the forum and wanted to post what resolved my TPMS problem.
My TPMS light came on at 300mi on my 08 Sentra 2.0S. After following the manual and using the reccomended 33 psi I decided to try something different.
1. With cold tires I adjusted to 34 psi and let the car sit overnight.
2. Checked cold tires again in the morning- all read 32psi re-adjusted to 34psi
3. Drove car 5miles and light went out and have had no further problems.
It seems to me that you need to do more than one cold tire adjustments to get the pressure accurate. As stated above there was a 2psi difference overnight. I'm going to do a cold check tommorow morning and see where they are at.
This worked for me hopefully it will helpl someone else.....
I work in the parts department here and we have had to replace several sensors so far this year and last year. Sounds like a common problem to me.dedlock wrote:Hello Folks, Just registered on NICO since we now own a new Sentra 2.0S.We compared it to the usual suspects but the interior room/comfort won us over.Enjoying the car, but the mileage is less than expected. Mid 20s on highway (calculated at fill-ups not w/trip computer. This seems to be mentioned by a few of you here.On the first 10 degree morning I noticed the tire preasure warning light come on and its been on ever since. Obviously a malfunction since pressure is correct. Anyone else experiencing this?
