PapaSmurf2k3 »
https://forums.nicoclub.com/papasmurf2k3-u3044.html
Fri Apr 08, 2011 7:37 pm
Is the torx bolt male or female? I've seen Nissan use male torx bolts before, that require a torx socket.
If I'm reading you correctly, its a male torx socket. If you're willing to bite the bullet and sacrifice a tool, you could make your own specialty tool. Cut enough of the torx socket off so that you'll have some wiggle room, and weld it on piece of steel (so in effect you now have a box end wrench with a torx pattern on it).
Of course, depending on how much those tools cost, you might be better off taking it to a shop and letting them deal with it.
