WDRacing wrote:Well, code P0725 = engine speed input/circuit malfunction. I did a little googlefoo and read about a few people also having this issue and changing out the crankshaft position sensor.
thank u for the warm welcome.
I did the same research as you and found just that online.
seems that most p0725 issues online are on mid-2000's altima's, especially ones which are causing the car to stall when at a stop or the rpm's to jump, or not to start at all.. my issue is no where are extreme as that (yet), but I need to address it before it gets that bad. I will likely be swapping out the crankshaft position sensor as early as this weekend.
I wanted to see if there were any more ideas out there.
