2008 Rogue Vibration Cargo Area Passenger Side
EHR
Car: 08 Rogue
For the last few weeks I've been noticing and increasing vibration-like noise that comes form the passenger side panel at the cargo area, close the where the small window is. Anyone had the same problem??
SenorPayne7
Car: 2008 Black SL AWD Nissan Rogue
check the forums, there are loads of these threads on rattling noises
Leo2005
When i turn the volume of the radio to the max my door panel starts vibrating. Time to use DynaMat.
EHR
Car: 08 Rogue
Any suggestions on how to install it on that particular panel? Thank you.
Leo2005
Same way as anywhere else. You have to take the panel off (if not sure how you should look in FSM) then try pre-cut dynomat for the panel and stick it to the wall. You will have to use heat gun or hair dryer to make sure it will seat for a long time. Before that try to open panels in your trunk and check for loose equipment such as tools.
EHR
Car: 08 Rogue
Leo2005 wrote:Same way as anywhere else. You have to take the panel off (if not sure how you should look in FSM) then try pre-cut dynomat for the panel and stick it to the wall. You will have to use heat gun or hair dryer to make sure it will seat for a long time. Before that try to open panels in your trunk and check for loose equipment such as tools.
Pardon my ignorance, but what is FSM? I just got my Rogue back from the dealer, they removed the panel to "check" for the noise but couldn't find the source, so guess I'll have to fix it myself, with some help with you guys
Leo2005
Factory Service Manual. Here's 2 links for you where you can download it from for free:I uploaded this one a while ago to rapidshare: http://rapidshare.com/files/12...e.rar This one is from Nico Club server as a mirror: http://www.nicoclub.com/FSM/Rogue http://www.crutchfield.com/p_1...=2277 Here's the link to the dynomat. You can find a video how to do it at this page.
EHR
Car: 08 Rogue
Thanks a lot, I appreciate it!
Return to “Rogue Forum”
