2008 Rogue Steelie Caps/Hub Bore Caps?
Blue Sky
Car: 2008 Nissan Rogue
Hey guys,
I was searching on here and found out that my hub bore is 66.1 mm. What I'm doing is I'm keeping the stock steelies and sandblasting them and priming them and painting them black. I will be adding gready racing long studded lug nuts to them. The only issue I have is since I removed the hubcaps there is no longer a center cap. I searched on ebay and found hub bore center caps. I was wondering if the stock center caps could fit on the empty circle hub bore or what I can put there because I rather have a center cap. Also I'm assuming I would need a center hub bore cap that's at least 40 mm off set with a 66.1 mm hub bore is that correct? Would that be enough clearance and would that be enough to keep them on the steelies at highway speeds. Any help is appreciated!!
Thanks!
New Member on here btw :mike
