joesera »
https://forums.nicoclub.com/joesera-u250907.html
Mon Jun 18, 2018 7:08 pm
The new clutch only came with 2 very thin shims. The old clutch had 3 thicker shims. Even with the 3 thicker shims, the gap was too narrow, causing the new clutch to rub when disengaged, so I added a 4th shim, which seems to have done the trick--clutch is stationary now.
I tried releasing some refrigerant from the low pressure port, and noticed the compressor stayed on longer. So I continued releasing refrigerant, and cold air started blowing from the vents. After a short drive (in 90 F heat), the compressor started short cycling again, so I released more refrigerant, and the compressor stayed on and vents blew cold air. Obviously the system was way overcharged. Compressor seems to be running (and cooling) good now.
Thanks for the tips!
