VStar650CL »
https://forums.nicoclub.com/vstar650cl-u299034.html
Fri Jan 21, 2022 2:13 pm
Unfortunately, there are a lot of possibilities. Spinning fast implies that it isn't getting either spark or fuel, and it wouldn't be the first fuel pump to get cranky when cold. To rule that in or out, spray some Brakleen or carb cleaner down the intake when it misbehaves. If it lights right off, suspect a weak fuel pump, low pump voltage caused by a crappy pump relay, or a corroded connector at the pump. If fuel doesn't help, pull a plug and see if it has spark. If not, you could have a crappy ECM relay, a dying cam or crank sensor (they're known to misbehave with temperature), or if it's a steel-key ignition, then maybe a crappy ignition switch.
