TaiLuu wrote:Not sure if this is correct, but someone should confirm this. When you do go to the junk yard, Look at some Altimas and see if the bushings fit. I doubt the sub frame would be the same but won't hurt to try it.
The Sentra uses different subframe, those bushings may not work.
Bebelo, are you sure you just don't have brake issues? If the subframe bushings were in fact broken, you would have alot more issues than just brake vibration, the car would almost be un-drivable!
Warped brake rotors will exhibit the exact same problems you are describing. I have already replaced the brake rotors on my Rogue for a similar vibration issue. Take your Rogue to any reputable automotive repair shop or a Nissan dealer and get them to check your brakes.
