J0B00 »
https://forums.nicoclub.com/j0b00-u85958.html
Fri May 11, 2018 1:09 pm
I apologize in advance as I know these topics have been coverd in-depth already. I've been reading a ton of posts on this issue, but I have some more specific questions.
I have a 2008 Rogue SL FWD with 179,000 miles on it. I still have the ORIGINAL CVT installed in the car (sounds like a miracle after reading this forum and complaints on the NHTSA website), and aide from a leak on the torque converter seal in 2013 and a leak that developed on an axle seal where CVT oil was dripping in 2017 (both repaired by the dealer - sorry, I don't remember the exact mileage on each of those issues), the car has been pretty great. I have not had any drain/refills on the transmission at all, except for when the above repairs were made. Aside from that, the only other "major" repair was changing out the fuel sending unit, which I did myself and was a piece of cake once I was able to find the correct tool to spin the sending unit out of the car. Saved $500 by buying a used part on ebay for $75, borrowing a 1/2 socket handle, and $120 for the wrench attachment to remove the sending unit. I digress...
Over the last few years I've been dealing with the "limp-mode" issue. For almost 3 years I did not know about any of this, except for maybe 2 long drives a year when I would have issues after about 400 miles of driving. I didn't really think about it much, but I figured out pretty quick that something transmission-related was overheating, so I'd either reduce my speed for half an hour of the 11-hour trip until it cooled off, or I'd stop for half an hour and let stuff cool off.
I recently experienced limp-mode on a much shorter, but very hilly drive last weekend, which was alarming as I had only driven about 100 miles. Did some research, ordered the aux cooler kit, and am planning on doing the install on that over the weekend. Before I do that, I have a few questions for those in-the-know....
1. How much fluid can I expect to lose when I pull the old beehive off? I have noticed that my CVT seems a little overfilled according to the dipstick, so I'm expecting a bit more will be lost when I remove the old beehive than a properly filled CVT. So I'm really wondering how much I should attempt to add back to get it back to the proper level. My plan is to add a little at a time, keep it hot, and check the fluid level until it looks normal.
2. Should I do this work with the car hot (drive around for 20 minutes first), warm (let it idle in my driveway for 5-10 minutes), or completely cold?
3. As far as I know (99% sure), the CVT only has NS-2 fluid in it at the moment as it's only ever had work done at the Nissan dealership. I have a quart of Valvoline CVT oil (NS-2 Compatible) to top it off with, but I wanted to ask if anyone thinks it would be a bad idea to top off the level with this instead of NS-2. I read that most only need 1/2 qt. to top it off after a cooler install, so my reasoning is that it wouldn't dilute the NS-2 very much and save a little money until.... (see #4)
4. I want to do a drain & refill a few weeks after I get the cooler installed and verify that everything is working correctly. I'm trying to decide between spending the money on NS-2 or going with Valvoline CVT Fluid (NS-2 Compatible). My concern is the age of the vehicle and switching to a fluid that may not be quite the same as NS-2, although "compatible". I've read some great reviews of the Valvoline fluid, though, so it'd be great to save the money.
5. On a CVT drain/fill, should the transmission & fluid be HOT, or is the procedure better done with the car cold? Does it really matter either way?
6. On the drain/fill, I've read that I should expect about 4.5 quarts to drain from the pan. Should I refill with 4 quarts even if 4.5 drain, then take the car for a short, easy drive and top it off from there? I want to make sure doing something such as that will not cause damage.
Forgive me if some of the answers to the above should be obvious. You could consider me a DIY maintenance "newbie", although I've helped plenty of friends on shade-tree projects like this in the past...I just never spent the time doing any of that stuff myself, unless money was an issue. Now that I'm doing this work for a project of my own and not playing go-fer, the details really matter to me.
Thanks in advance for the advice!!
