2008 Rogue AWD SL - Can i remove Rear Shaft drive and use
shaw22
Car: Rogue 2008
Hello,
My Rogue AWD has 176000 miles -
Rear Propeller Drive Shaft Assembly needs replacement - $600 part - mechanic took it out and told me I can drive with just front wheel drive.
Is it ok ? will driving without the rear propeller drive shaft assembly for 7 months / 15000 miles (until winter) cause problems ?
Thanks
Shaw
Reason: fix image link
PapaSmurf2k3
Site Admin
As long as the yoke doesn't come out of the transmission/transfer case (and spill fluid everywhere), you should be good.
shaw22
Car: Rogue 2008
Thank You,
Is there anything that I can do to make sure the yoke dont come out and spill trans fluid ?
ImStricken06
Car: 2008 Nissan Rogue (sold)
2013 Hyundai Santa Fe
2016 Kia Sorento
idk if the yoke is bolted to the pinion gear, like in traditional systems- or if our's are press fit via a snap ring (since the shaft isnt supposed to be removed!) kinda like the way subaru cvt joints are.
i would caution you on this, simply due to the many sensors on our car. idk what could trigger something to 'think' its slipping, and end up constantly having an electrical device 'ON', thus burning it out prematurely.
this car isnt a 90's jeep wrangler, or an 80's bronco where the drive-train was 99% solid state. we have clutch packs, sensors, actuators, etc. dont forget, our car is a FWD, and it kicks off power to the rear wheels from the transmission. versus that of early awd vehicles that were rear wheel drive, and kick off power from the transfercase to the front wheels.
shaw22
Car: Rogue 2008
thanks imstricken - i found a prop shaft assembly on a 2010 rogue awd with 53k miles on it - for $150 - do you know if it can be used on 2008 rogue ?
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
shaw22 wrote:Is there anything that I can do to make sure the yoke dont come out and spill trans fluid ?
Have the work done by a qualified mechanic.
The part you found 100% compatible with your vehicle.
Reason: Typo
Return to “Rogue Forum”
