2008 Rogue ac compressor
morselicious
Car: 2008 Nissan Rogue SL AWD Gothem Gray/350K@sold
2009 Toyota Rav4 /sold
2011 Toyota Rav4/sold
2018 Toyota Rav4/sold
2001 Rav4 AWD /Black/ 130K (present car)
Does anyone know if the 2008 Rogue ac compressor is the same unit in all the following years. 2008,2009,2010,2011,2012? My compressor has a seized bearing and I need to replace it to start and drive.
darylzero
I bet the 2008 & 2009 are the same. The '10, '11, '12 might be different from the '08 & '09.
Rockauto might tell you for sure. http://www.rockauto.com
why do you ask btw?
morselicious
My 2008 Rogue has 180,000 miles on it. The bearing has been going for a few months and tonight seized. I had to get it towed home. I know the dealer price is over $500. I have been unemployed and want to do it as cheap as possible. I am a backyard mechanic and will want to do the labor myself. I need a replacement compressor and a local recycler has one for a 2011 for $180. Just my price range.
darylzero
according to this ebay listing it should work.
Also, looking at Rockauto.com both the '08 & '11 have the same OEM# 92100JG000
morselicious
Thank you sir. I have seen the same remanufactured part with the same part number for all the years. On another note, I see that you have a 2009 SL AWD, what kind of milage do you have?
darylzero
No problem. I'm at 35,000 miles
Nissan92
Car: 2009 Nissan Rogue AWD
morselicious -
What symptoms did you have before the a/c compressor finally seized up? Noises, vibrations, locations of those, etc.....I have a 2009 Rogue AWD with 70k and just want to know before it happens to wife out on the road. Thanks.
Return to “Rogue Forum”
