2008 QX56 suspension
A forum for the Nissan Armada, Infiniti QX56, and beginning in 2014, the Infiniti QX80
zepol379
Car: 2008 qx56
My qx56 is riding really soft. It seems to rock side to side on little turns. Took it to my mechanic and front struts and coils seem ok. also checked back shocks also ok. they took for test ride and agreed something not right. Any ideas on a possible first step to correct 2008 qx56 with 62000 miles. thanks
marctronixx
change the shocks to bilstein. do you have the auto leveling system?
zepol379
Car: 2008 qx56
Yes I have a leveling system. You mean the airbags, correct ? Any model of bilstein's better than others? Think that will stop the swaying? Thanks
marctronixx
yeah i know a lot of cats who have switched to these in front and it really helped "bump steer".
i had two armadas before getting my 12 q and on my 08 armada , although i NEVER had any issues with bump steer (i also had 24 inch wheels on it) i switched to those shocks and they were amazing.
I cant guarantee this will cure your issue but these shocks are famous on armadas! i am a member of another armada site that is VERY active and many of them agree on these shocks.
the bags in back you should leave those alone in my opinion.
although you have a qx, its essentially the same car as the armada as they are all made on the same line with the titan, so if you are doing any internet research, expand your search to your model year with the armada/titan.
zepol379
Car: 2008 qx56
Thanks for the advise. Will try the front shocks.
zepol379
Car: 2008 qx56
put in the 4600s and am very happy. The ride is fantastic. thanks for the input,
marctronixx
glad you figured it out.
Return to “Armada Forum / QX56 Forum / QX80 Forum”
