2008 Quest Antenna Amp
A forum for the Nissan Quest... minivan lovers unite!
kodibook
Car: 2008 Nissan Quest
I have a 2008 Quest with a problem with radio reception. All bands are static-filled, although the AUX channel (which I use for Bluetooth) and the CD work fine. This has me suspecting the antenna amp. Where is it located? Is replacing one a big deal?
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
It's in the roof above the righthand rear door. See AV-80 here:
https://www.nicoclub.com/service-manual ... 8%2Fav.pdf
EDIT: lefthand :blush:
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
Nissan 28231-5Z000 Amplifier-Radio
2004-2010 Nissan Quest
Trim & Engine: Base, S, SE, SL|6 Cyl 3.5L
Part Description: Amplifier-Radio
Lookup Code: 28231 (in the diagram below)
2008 Quest FSM
Return to “Quest Forum”
