jbeaches3 »
https://forums.nicoclub.com/jbeaches3-u286058.html
Tue Oct 09, 2018 9:09 pm
2008 with rough idle and throwing P0300 code. It all started when one of my kids drove the car while it was overheated and it quit running. After it cooled it restarted fine. I had the overheating problem fixed with new hoses, thermo, had timing chain redone, new plugs and coil boots, all fluids changed, new head gaskets and bolts,and new throttle body. Compression was well in the acceptible range. Now have a rough idle and random misfire. Runs good at rpms above 1500. Bad gas mileage. No vacuum leaks found. STFT on bank one 25% STFT -25% at idle. They both will move toward 0 at higher rpms. Changed upstream o2. Need help.
