2008 pathfinder S fog light install
vapathy
Has anyone installed fog light on an 08 Pathfinder "S"? Was it difficult, and what are the steps?
Edi. G.
Car: 06. PATHFINDER, S MODIFIED
I have an 06 and thinking about doing it, but i'm looking to replace my headlights first.to put the foglights it should be easy and the cars come prewired, however, you are going to need a switch or jump it.How i'm not sure.
Buzzman
Car: 2016 Lexus RX 350
2023 Kia Stinger Elite V6 AWD.
If it's anything like the R50 Pathy's , then it should be easy.The lamps will be prewired, so all you need are the actual fogs. Probably OEM will be your best bet.You will also need a new stalk that has the fog light switch in it. Plug and play replacement there too.Lastly, on the older ones anyway, you will need to install the fog light relay.It usually isn't there if you don't have fogs already.Hope this helps and that the '08 is not too different.
