Before doing anything, make sure the gas cap is secure, clear the code and see if it comes back.
Next visually go over all of the EVAP components, and see if you can find any cracks, cuts, or disconnected vacuum lines.
If that doesn't bear fruit, get a new gas cap. If you do, get OEM (though I used Gates and had no problem).
P0455 basically means there's an egregious leak somewhere in the EVAP system. The common culprits that I've seen around here are gas caps and charcoal getting lodged in the vent control valve. However, since you aren't getting any accompanying codes (and your 08 vehicle shouldn't be old enough for the charcoal to disintegrate yet), I'd focus on the gas cap and filler neck first.
Do you hear air being sucked in when you pull the gas cap and the fuel level is lower? Do you smell gas anywhere? Gas odors would be a really strong indication of where to look.
Some links that may help if you haven't read through them already:
post6554628.html
post5493422.html
http://www.nicoclub.com/FSM/Pathfinder/ ... der/ec.pdf
Let us know what you find!
