Hey i got a system put in and used the factory head unit.. they used an adapter from the rear speakers. ill take pics if you want.. and tell you more if you havent started on your project!kamau212 wrote:How do you remove the radio in the sentra??I have an amp i want to install but i have no idea where to start when it comes to removing the stock radio
Yea, I don't know about kamau212 but I'm stuck. If you could take pics and do a write up on how to remove the audio unit, that would be great! It'll be nice to put up more guides for the B16 Sentras. Thanks 08sentra2.0sl!08sentra2.0sl wrote:Hey i got a system put in and used the factory head unit.. they used an adapter from the rear speakers. ill take pics if you want.. and tell you more if you havent started on your project!
gforever, I would, however I am not by any means experienced enough to do a write up. I will do some digging to see what i can find do help.gforever wrote:
Alright so I'm trying to swap my stock radio out and am still struggling with this... Yea first timer... So here's the furthest I got so far.....anhktruong;3615445 wrote:1. remove the shift knob by putting it into neutral and sliding the chrome cover down. once that is down, remove a metal clip that is right under the shift knob...now the whle thing should slide right off.
2. remove big grey plastic surrounding the shift knob and dash area; not the piece that has "P R N D L", but the whole piece. It is just held on by clips so get a flat head screw driver and it will pop off...(note, you will have to disconnect wiring so do NOT yank it off.
3. now remove the climate controls, this piece just pops right off too. You wil have to unplug things here too so do not yank too hard.
That's amazing that you've removed the radio so many times. How do you get the top cover off without damaging the plastic piece? Thanks.bundy26 wrote:.. and 2 screws on top of the console (have to remove cover on top of the console)
I get bored, 5 th radio I changed already on this car.I used a real flat and thin screwdriver ,do it slow and with patience and the plastic cover will come out without damage.gforever wrote:Finally got the AC piece out without taking out the wires. Pull the AC piece upwards and out.
Torx is correct, between 20 and 30 in size, great job.Faja wrote:I don't remember what type of screw was there but if it's not one of your normal ones then you probably need a Torx screwdriver with the correct bit size.
