2008 Nissan Quest Block Heater Cord Location???
A forum for the Nissan Quest... minivan lovers unite!
JakeRondoBeckett
Car: 2008 Nissan Quest
Can't seem to find the block heater cord in the bay of my 2008 Nissan Quest. It's god awful cold here in Canada right now and she won't start. Thanks for your help in advance.
PS: She has the 3.5 V6
04pathse
Car: 2004 Nissan Pathfinder SE
2008.5 Mazda Mazdaspeed 3
on most vehicles the cord is usually coiled up near a headlight or front grille.
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
This is from a different vehicle forum but it might help.
The best place to hide something is within plain sight, and the block heater plug is no exception. I finally spied the 2 to 3ft cord wound up sitting atop the engine compartment on the driver side in-between the engine block and the side of the car. The cord is wrapped in that black plastic flexible protector with the 3 prong plug/cover at the end.
If you still can't locate it, then it may not have the block heater installed. This video will give you an idea of where the block heater goes in the engine. I'd check that to see if there's a cord attached.
Return to “Quest Forum”
