2008 Nissan Quest bad fuel pump?
A forum for the Nissan Quest... minivan lovers unite!
Myproblemchild
Car: 2008 Nissan Quest
Sorry if this was posted, but I am having issues with a used replacement engine I put in my van. Every time I start the van I get a puff of blueish smoke. After a week of driving the van I check the oil and it is 4 quarts low. Went thru a car wash and now it is barely moving. Is it possible that the fuel pump is bad and is causing these issues??
Reason: Revise Title
Myproblemchild
I also bought a fuel pump, just in case.
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
Check that your PCV plumbing is routed correctly and that your PCV Valve is good, but if it is, it sounds like you bought a clunker that has either bad rings or very bad stem seals. An '08 has an internally-regulated fuel pump, and since your crank obviously isn't filling with gasoline, the fuel system isn't your problem.
Myproblemchild
Someone said that around 200-220k the fuel pump doesn’t work as well or not at all
VStar650CL
Technical Expert
Myproblemchild wrote:
Thu Jan 27, 2022 11:44 am
It won't cause blue smoke no matter how bad it is, and it can only cause loss of oil by overpressure that fills the crank with gasoline. Your crank was empty, not overfull and thin. I'm afraid you're barking up a completely irrational tree.
On the other hand, a bad PCV or improperly-routed PCV plumbing can definitely cause catastrophic oil usage. That's the right tree, and if you don't find anything there, then you simply bought a bad engine.
macgiver
When you bought the engine , were you able / allowed to start it before you buy ? Was there ANY blue smoke like your seeing now ?
Myproblemchild
No it was sent to me giftwrapped n a pallet
Myproblemchild
To get a routing of pcs valve and vacuum lines where or what site do I need to go to?
Myproblemchild
Pcv valve,damn auto correct
VStar650CL
Technical Expert
Myproblemchild
Thank you I’ll check tomorrow if it’s warmer outside
Return to “Quest Forum”
