For the cigarette lighter, you are looking for a 15A fuse. The fusebox will be on the right side footwell/kickpanel. Open the plastic cover and you should see 2 rows of fuses. The fuse holder/remover should be on the left row. That 15A fuse directly below it is what you need to check.The cover should be labelled "CIGAR LIGHTER"
Something like this: (different vehicle, only linked for illustration purposes)
https://forums.nicoclub.com/major-fuses ... l#p6780237
For the other power outlets, you need to check 2 fuses.
1. The same fuse discussed above
2. A 20A fuse
This one is located in the engine bay, by the battery. I believe it's the one closest to your positive terminal. Open the cover and you'll see 2 20A fuses. It's the rear-most one.
