2008 M45 Repeated APP Sensor Problems
Big_Tone
Car: 2011 Infiniti M56x (White w Java interior; Tech Pkg)
PPE Headers; HPS Intake
Custom 2 1/4” exhaust with Jones Exhaust X-Pipe
Infiniti Sport mufflers
Hey guys. As the subject states, I've been having repeated problems and repairs connected to the APP sensor. It has been replaced three times. Last week while driving home all of my sensors went off and I lost HP. I took it to Infiniti of Orland Park and they think there's something that's causing the sensor to go bad, but don't know what it is. While they have it connected to their scanners, the car runs fine. As soon as they connect everything back, it goes back into safe mode. I had a new battery installed, and the problem is still occurring. I know there was a recall for this, but like I said, the sensor has been replaced three times already! The service department is very helpful and want to fix this once and for all (as do I!). Does anyone know what else could be the cause of this? Anyone have repeated problems with the APP sensor? I'm very frustrated!
svard75
Car: 06 M35x
If repeated dtcs for the APP sensor the fsm states replace the abs mechanism and electronics. It has to do with the accelerator pedal correct? Did they replace the pedal assembly as per the recall?
Big_Tone
svard75 wrote:If repeated dtcs for the APP sensor the fsm states replace the abs mechanism and electronics. It has to do with the accelerator pedal correct? Did they replace the pedal assembly as per the recall?
Hi svard75. Yes, the pedal assembly has been replaced. What is fsm?
svard75
Car: 06 M35x
Factory service manual I think. It's in my sig
Big_Tone
svard75 wrote:Factory service manual I think. It's in my sig
Got it. I'm looking through the pdf files now and am unable to locate which one discusses my problem. My goal is to direct the service department to exactly where they can find the recommended repair for my problem. Do you know which file provides the solution?
Big_Tone
Nevermind. I found it!
Big_Tone
OK, so I found the section regarding the APP sensor (EC starting on page 550), but what I cannot locate is where it states if this occurs repeatedly that the ABS mechanism and electronics need to be replaced.
svard75
Car: 06 M35x
P120 of ACS.
Big_Tone
svard75 wrote:P120 of ACS.
THANK YOU! Calling the dealership this morning with this information.
Big_Tone
So I finally got my car back last night after being in the shop for a week. Apparently there was a wire in one of the harnesses that was damaged. They repaired the wire and all appears to be well now. THANK YOU svard75 for the info and directing me to the FSM.
svard75
Car: 06 M35x
Good to hear! Don't thank me, thank nicoclub for hosting the FSM's.
